So, 735 miles on my 2022 CFTP. Changed oil at 650 miles, I reused O-rings on filter housing and oil leaked there. Replaced them with new, no more leak there. Went on a drive yesterday and noticed burning oil smell. Got home and here's the result. Somehow, oil is leaking down the manifold, engine mount and onto the belly pan. As you can see in the photos, there's oil on the exhaust manifold studs. Not sure how oil would get that high up on the motor.
Belly pan is off, ran car on jack stands, cant find the leak. Plan on driving it in the next couple days once it is dry out hoping that getting it hot and getting good oil pressure will expose the leak. Appreciate you all's thoughts.
Sensitive content, not recommended for those under 18
Show Content
