Welcome to the forum! Top your trans off with fluid. They come low from the factory.
Welcome to the forum! Top your trans off with fluid. They come low from the factory.Hi everyone its my first post and i have 2020 gt500 with whipple supercharged and i have issues and I don’t know if anyone have same issue the issue is while shifting between gear to another you fell it jerking and when i stop the car and switch it off and on again the issue will go than it will be back again after I drive the car so any one have same issue
thank you
I have no idea what I’m looking at in those pics. Are you saying the shifting problem is an engine issue and not a trans issue? Did you check your trans fluid level?There is data log picture when everything fine you can see the timing is ok and there is pictures when the issue is coming you can see the timing is not ok and also the short term is -15 and over
And that issue you can fell it only when the car shift from gear to another only
View attachment 277625 View attachment 277626 View attachment 277627 View attachment 277628 View attachment 277629 View attachment 277630 View attachment 277631
not yetI have no idea what I’m looking at in those pics. Are you saying the shifting problem is an engine issue and not a trans issue? Did you check your trans fluid level?
