To check for plugged cats remove the pre o2 sensors use an adapter to fill the hole where the o2 sensor was removed and hook up a pressure gauge, I usually use a old valve stem that I cut/grind down with the core out because I am to cheap to buy an adapter ( obviously the vehicle is cold) start it up and rev it to 2000 rpm you should have less then 1 psi.
Also if you have a scan tool look at the fuel trims if the converter(s) bad the fuel trim should be on the neg side (more exhaust getting left in the cylinders leaves less room for O2 which means less fuel) this may also help you determine which bank is bad if you do have a converter problem.
Another thing I would check is your fuel pressure, as your pump may be getting lazy and only supplying a fraction of the pressure, an indication of this can be seen in fuel trims as well, near 0 or slightly pos at idle then the further you get into the throttle the numbers will continue to get more pos may be somewhere +30% at WOT.
Long term fuel trims is what you want to look at LTFT these are corrected #s
