i am a autobody tech with 40 years of experience.
pretty much ALL cars have similar holes in the trunk lid. there are usually similar holes in the hood also.
sometimes there are rubber plugs in the holes instead of tape.
my guess is those really aren't drain holes for moisture, aka water, in the trunk. they are drain holes for the E coat primer to drain out on the panel when the car was built. when i toured a GM build plant many years ago the hoods and trunk lids were installed and open when they entered the E coat primer dip tank
i would assume they tape over the holes to prevent moisture from getting inside the panel when it's on the road. on some cars the tape is under the paint.
for the most part water builds up in the tail end of the panel causing rust, not the front so i wouldn't worry about it.
will moisture build up inside of the T lid later on? my opinion is yes so it wouldn't hurt to remove the tape.
