1 - 3 of 3 Posts
2010 Grabber Blue GT500
dropped a bolt out of the power steering reservoir bracket while installing the driver side oil separator and cant find it....somewhere down in the frame. What size are those oem bolts in that bracket. Thanks in advance.
203455
It’s probably sitting on the plastic belly pan... ask me how I know!
You can lay on your back and hit the pan from below... if you hear it rattling around, you now know where it is. Get it from the top with a magnet on a telescopic stick or remove your pan and get it from below. Also look through your wheel wells.
Thanks man its been a pain in the neck. Should of been done with this little job hours ago 😣
1 - 3 of 3 Posts
