Does anyone know where I can a get one of these. Ford no longer makes them. Maybe New Old Stock?
Thanks
Mike
Thanks
Mike
Welcome to the forum! You could always try a Mustang salvage yard.Does anyone know where I can a get one of these. Ford no longer makes them. Maybe New Old Stock?
Thanks
Mike
A few years ago I replaced my original mint condition 2008 GT500 battery blanket with the one that Ford listed in the parts application. Shown below is the original from my 2008 and the plastic parts bag from the new one that is currently on my Motorcraft replacement battery....Does anyone know where I can a get one of these. Ford no longer makes them. Maybe New Old Stock?
Thanks
Mike
I know the battery terminals face the firewall on 2007-2009 and face forward on the 2010-2014......Not that it would make a difference with the battery blanket?......Not sure how they differ from 07-14. Also, have you checked eBay?
Thanks
Mike
Check this one also... looks like the part # you have has been superceded.Does anyone know where I can a get one of these. Ford no longer makes them. Maybe New Old Stock?
Thanks
Mike
Yes, ^^^^^that blanket is what I showed in my post #4. That is what Ford sold me as a direct replacement for my 2008 GT500. I really didn't need one with a battery replacement, but my "slightly different" correct original was so nice I wanted to save it. the new replacement is on my 2008 now, but hidden under a Shelby battery cover.....Check this one also... looks like the part # you have has been superceded.
(1) NEW OEM Ford 2005-2014 Mustang Focus Battery Heat Shield Cover AR3Z10A687A | eBay
(1) NEW GENUINE OEM Ford 2005-2014 Ford Mustang Focus Battery Heat Shield Cover OEM AR3Z10A687A. 2005-2014 FORD MUSTANG. 2007-2010 FORD MUSTANG SHELBY GT500. 2008-2011 FORD FOCUS. GENUINE FORD PART NUMBER: AR3Z-10A687-A.www.ebay.com
Yes I have. The ones you can get from CJ's and LMR are to small. Both of my 07's are the same size batteries. The part number above came off the old blanket.Not sure how they differ from 07-14. Also, have you checked eBay?
What series batteries are in your 2007's?Yes I have. The ones you can get from CJ's and LMR are to small. Both of my 07's are the same size batteries. The part number above came off the old blanket.
Thanks
Mike
^^^That is the difference in finding a correct fitting battery blanket.40 series.
You're welcome. So I am guessing electrolyte has damaged you original blanket(s) and that is why you are trying to find replacements?Yes, mine are both 40R, 11x7x7.
I like this site a lot, thank you all for the help.
Yea, I'll keep hunting. I just wanted to replace it to clean up the engine bay, I'm going to sell it. 7900 original miles.You're welcome. So I am guessing electrolyte has damaged you original blanket(s) and that is why you are trying to find replacements?
^^^^If that is the case, and you can not find the correct original cover(s), the next option is to identify what Ford applications use the 40 series battery and then find which of those use a blanket. The 2015/16 Ford Transit uses a 40 series, but that application has a full plastic box around the battery instead of a blanket.
It will come down to doing some research and if you have a friend at Ford Parts, that also helps to narrow down the search.......
OR change to 96 series batteries and their much more readily available blankets?
Ok, good luck with your search and sale.Yea, I'll keep hunting. I just wanted to replace it to clean up the engine bay, I'm going to sell it. 7900 original miles.
Thanks again
