Shelby Cobra GT500 Shelby Cobra GT500 Header Right
» Featured Product
» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   Ford Shelby Cobra GT500 Forum > Ford GT500 Discussions > Performance Modifications
Register Home Forums Active Topics vBPicGallery Search Today's Posts Mark Forums Read
Please Visit our Site Sponsors
FordGT500.com is the premier Ford GT500, Shelby GT500 Forum on the internet. Registered Users do not see the above ads.
Thread Tools Display Modes
  #1
Old 04-30-2008, 08:04 AM
Coldwaterhotrod's Avatar
Coldwaterhotrod Coldwaterhotrod is offline
Junior Member
Coldwaterhotrod is on a distinguished road
Default Steeda Watts Link?
I just got an email from Steeda & they have now came out with their own version of the Watts link. see pics & link for more info. Not sure I like the design of it vs. the Fays2 or Saleen Watts link
http://www.steeda.com:80/news/steeda...ts_linkage.php
Old 04-30-2008, 08:24 AM
joegaz's Avatar
joegaz joegaz is offline
joegaz is on a distinguished road
Default Re: Steeda Watts Link?
I think I like the fact that it has dual axle tube clamps as opposed to a single pivot bolt diff cover design
__________________
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Concealed Carry, don't leave home without it.
  #3
Old 04-30-2008, 09:14 AM
GT500-07 GT500-07 is offline
GT500-07 is on a distinguished road
too late the Fays2 is installed
  #4
Old 04-30-2008, 11:02 AM
WP64's Avatar
WP64 WP64 is offline
Newbie
WP64 is on a distinguished road
First off let me state that I have the Fays2 Watts and it's been installed on my GT500 since last Fall.
Here's my first impression after seeing the picture and reading Steeda's cover:
1) This design is not a true 'center-pivot' design, but nether is the Fays design. What am I saying? A frame mounted center pivot design, like this Steeda and Fays, are only 'correct' (speaking of correct suspension geometry) at the point it is set and leveled when the suspension is static, ie not moving up and down; once in-motion the 'correct' suspension geometry will change as the suspension moves. This is the inherent problem with a frame mounted center pivot design. Fays (Jim) says that their system can be pre-loaded to account for suspension movement, but IMO it can only be 'corrected' so much and at a compromise, when it's pre-loaded for one set of parameters it will be incorrect when a different set of parameters is encountered. This is also one of the reasons why the Fays and Steeda designs allow for adjustment of the center pivot bolt up and down on the frame and the Saleen Watts has a static position for the center pivot bolt on the diff. cover, there is no need for adjustment on the Saleen's center pivot bolt because it's in the correct position all the time because it's able to move up and down with the rear-end as the rear-end moves up and down. The Griggs Watts is different in-that it is a rear-end mounted system (true center pivot) but Griggs provides adjustment, up and down, of the center pivot bolt for adjustment and pre-loading which is what Griggs GR40 system is all about, adjustability...
2) I would question the design of the rear-end mounting arms. The Fays has a full collar that clamps down on the rear-end over apx. 90% of the clamp rings surface area, this Steeda design, as the picture appears, only clamps down upon the rear-end on its sheet metal surfaces, maybe utilizing 15% of it's surface area. I have found that this is a critical area of the Fays design and besides the center pivot bolt, the rear-end clamps are subject to the most stress in this design. These arms have to be held firmly on the rear-end and cannot move at all or the entire systems geometry is jeprodized. Also, by using sheet metal (Steeda) the rear-end axle tubes are subjected to a lot of clamping pressure concentrated in a thin area, I would think (I'm not an engineer) that there could be a possibilty of distorting the axle tubes, probably not bending them, but dimpling them where the arms clamp onto the axle tubes.
I suspect most of us are of the "set-it-and-forget-it" vain, if that describes your needs, the Saleen is the best Watts design/system IMHO; my opinion has been shaped by exhaustive research, talking to the manufactures, less Steeda, and talking to people using the various systems and installing/using the Fays system on my own car..
Just my first impressions on the Steeda Watts above and I'm not a difinitive expert on Watts link systems for our cars and I'm not an engineer. Just so you know the direction I'm headed (if you care?), this Fall I will more than likely be installing the full Griggs GR40 rear-end suspension system. Why the Griggs? Because of the torque arm and the true center-pivot Watts link design/equipment in the Griggs package. But if I wanted something simple to install and a "set-it-and-forget-it" system, I'd go with the Saleen Watts and would 86 the Fays that I have now and install the Saleen... But I want the adjustability and the torque arm.
Hope that helps,
Jay
  #5
Old 04-30-2008, 04:23 PM
Svtbird91's Avatar
Svtbird91 Svtbird91 is offline
Svtbird91 is on a distinguished road
I agree with your analysis here Jay . The main reasons I have gone with the Saleen Watts link are:
True center pivot.
Ease of installation
Most factory like
No increase at all in NHV
My exhaust system location (X pipe )doesn't allow for a center torque arm like the Griggs uses otherwise I probably would have gone that route.
I've had mine on for about 6 months now and have to say I love it . The car takes the bumpy roads much better than with the PHB.
__________________
1991 Tbird 537rwhp 11.57 1/4 mile
2001 Lightning/red 12.5 1/4 mile
2007 Vista blue/white ShelbyGt500
(around a road course as fast as possible)LOL
  #6
Old 04-30-2008, 06:36 PM
TrickyDick's Avatar
TrickyDick TrickyDick is offline
TrickyDick is on a distinguished road
True center pivot.
Most factory like
How much is the Saleen Unit?
Sounds like you need to swap the diff cover (Another $50 in synthetic diff oil!)
Would this interfere with the 335/30/18s that JCThorne was posting about?
TD
__________________
07 Performance White Red Stripe Ed.
some mods
  #7
Old 04-30-2008, 06:49 PM
Svtbird91's Avatar
TD
Call JDM for a price http://www.teamjdm.com/shop/product_...roducts_id=228
Yes it comes with a new cover . You will have to change the fluid and add some friction modifier (unless you reuse the existing fluid)
I don't think it would interfere anymore than the stock panhard bar and brace.
__________________
  #8
Old 04-30-2008, 07:31 PM
TrickyDick's Avatar
Thanks!
They list $995 for price.
Is this the set you have? Do you know if that diff cover has internal supporting braces (think the FRPP one does).
__________________
some mods
  #9
Old 04-30-2008, 08:17 PM
Svtbird91's Avatar
Thanks!
Yes this is the one I have on my car.
There are no added support bolts internaly but the cover itself is reinforced.
It also includes a GT500 sway bar but it is the same as the one already on our cars.
You have to remember this is the same as the one on the Saleen PJ car our sway bar is already larger than the reg GT.
__________________
You may not post new threads
You may not post replies
vB code is On
Forum Jump
Tranny noise video link Ridin Dirty General Discussion 9 04-30-2008 04:19 AM
Steeda HID Lighting TexasShelby General Discussion 1 02-06-2008 12:46 PM
Steeda 2008shelbyvistablue Performance Modifications 6 11-30-2007 09:20 AM
Steeda Coldair System Veezerboy Performance Modifications 13 10-25-2007 01:04 PM
Steeda Mustang busababy Pics and Vids 2 01-14-2007 03:41 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© AutoGuide
