1-2 Grind TSB coming - Page 11 - Ford Shelby GT500 Forum
Problems/Dealer Service Having a problem with your car? Not getting the service you expect from your dealership? Let's talk about it.
post #101 of 278 (permalink) Old 06-13-2012, 07:17 AM
SRT8Tech's Avatar
Re: 1-2 Grind TSB coming
^^^^^^Ahhh, so it still happens. Great, just great. Its starting to sound like we are stuck with granny shifting from 1-2.
2013 SuperBee........................
Best with CAI, Drag radials and Tune......12.008 @ 115.76
SRT8Tech is offline
post #102 of 278 (permalink) Old 06-13-2012, 11:59 AM Thread Starter
Junior Member
My 2011 is still working great after the last fix.
Has anyone that has gotten the replacement clutch and shifter parts still had the grind?
SEMPER FIDELIS
Madeuce is offline
post #103 of 278 (permalink) Old 06-13-2012, 02:23 PM
SRT8Tech's Avatar
Do the 2012's have the "updated" clutch???
SRT8Tech is offline
post #104 of 278 (permalink) Old 06-13-2012, 02:35 PM
TXSVT's Avatar
No...............
TXSVT is offline
post #105 of 278 (permalink) Old 06-13-2012, 04:29 PM
SRT8Tech's Avatar
Originally Posted by TXSVT View Post
No...............
Looks like imma gonna need a clutch soon then LOL. Right after my 2500 mile road trip.
SRT8Tech is offline
post #106 of 278 (permalink) Old 06-18-2012, 11:55 AM
chris410's Avatar
Quote from the 2013 1st to 2nd gear post since it may be relevant.
Originally Posted by grayghost View Post
Check out Panzerfaust's solution:
http://www.svtperformance.com/forums...04-post58.html
This is an old issue with (in my case) a simple answer, but my theory is that you have to take action to correct the BS factory shifter issues BEFORE you make repeated grinding/clashing 1-2 upshifts which will damage the trans and compound the problem into an issue that requires warranty action. The issue (I believe) is that the factory shifter stick (NOT the factory shifter) is the culprit here. It is so over-isolated with rubber bushings that it makes experienced manual trans users look like rookies.
With over 25 years of man. trans. use under my belt, I was humiliated by clashing gears on the 1-2 upshift on my 2011 GT500. It happened to me 2-3 times (and I read about it all over the web) and I immediately went into diagnosis mode. Sitting in my car in my driveway with the engine off, I ran through the clutch/shifter motions of an aggressive 1-2 upshift repeatedly, something I'd done thousands of times in reality, with no problems.
Then I slowed down the clutch/shifter movements I make, into slow motion. Lo and behold, I could feel that as I moved the shifter handle from 1st to 2nd, when I hit the shifter stop at second, there was a secondary, almost imperceptible movement of the handle a tiny bit to the rear and I could feel an additional mechanical sensation through the handle. That sensation was the final, full engagement of 2nd gear.
Though I had, in my mind, been timing the release of the clutch by my left foot to the arrival of the shifter handle's end-of-rearward-travel into second gear, that was not the case.
The culprit was the ridiculous factory rubber-mush isolation of the shifter stick. It was NOT the body of the factory shifter proper. What my 25 years of man. trans. usage had programmed my brain to do was to release the clutch when my right hand stopped noving rearward. Because of the over-insulation of the factory shifer stick, there was a fraction-of-a-second of a delay between the shifter hitting the second gear shift stop (thus compressing the rubber isolators) and the rubber isolators on the stick having time to rebound (de-compress) and then transmit the force from the shifter stick to the shifer body and finally get the second gear shift to complete.
Sounds hoakey I know, but a fraction-of-a-second mis-timing of clutch release to gear engagement will result in a gear clash. Below is the text of my post to Team Shelby.com (post #29 on the thread at: Shelby GT500 Shifter vs. MGW - Team Shelby - Page 2 )
I simply bolted up (with NO RUBBER ISOLATION) a Hurst stick to my factory shifter and I've never had the grind since. Because I caught it early enough, there was no harm to the trans. Your mileage may vary.....
Team Shelby post now follows, pics are on that thread:
Before anybody runs out and spends hundreds of dollars on an aftermarket shifter and the labor to install it, I'd advise trying what I did. When I got my 2011 SVTPP Shelby, the shifter felt rubbery and I was having the 1-2 upshift grind problem. I was planning on getting an MGW shifter, but decided to tear down the stock set-up first to see if I could improve it for less $$$. Lo and behold, the stock stick has more rubber on it than a high school senior on prom night.
I realized I had been having the 1-2 grind because I thought the car was in second gear and had been releasing the clutch too early, while in reality the over-rubber-isolated stock shifter stick was not transmitting my force on the stick to the actual shifter arm. The trans was not fully in second gear when the clutch was released, hence the grind.
I bought a Hurst chrome stick (#7201) off eBay for $40. It came w/ 2 bolts with bushings that adapted the smaller-diameter metric bolts to the larger 3/8" bolt holes on the shifter and it also came with the rubber boot adapter. Shifter stick has 3/8" coarse thread for your choice of knob. I bought a Roush shifter boot from JEGS for ~$30 and it fit the boot adaptor like a glove. I removed the stock stick and all the rubber isolators, installed the Hurst stick (bolting it directly to the stock shifter w/ no rubber isolation), the Roush boot and a Hurst T-handle I had lying around my garage. Total install time was about 60 mins and was done entirely from the driver's seat.
Result is an expenditure of ~$75 for a shifter that works with the rock-solid feel of a bolt-action rifle. It was an unbelieveable difference over the rubber mush crap that came from the factory. It has virtually no rattle or vibration and the 1-2 grind issue is gone. It cranks off 1-2 upshifts with ease. I did re-discover the fact that the aluminum t-handle gets a bit warm in a sunny parking lot. I also have about a half-dozen shift knobs I've acquired over the years, including a vintage 1960's-era Muncie pattern knob and a Mopar-esque pistol grip, so I switch them up from time to time for some variety.
So, before you throw the baby out with the bathwater, the problem w/ the factory shifter is the rubber isolation that they install. They totally over-do it, so that there is never a complaint from somebody who buys a Shelby and complains about shifter vibration because they expect a Rolls Royce level of cabin noise......just throw out the bath water (the rubber isolation) and keep the baby. You'll save a lot of $$$$. If you don't like it, you can always subsequently buy an aftermarket shifter and re-sell the Hurst stick on eBay.......
Chris
former car: 2010 Kona/Silver #84 of 844
2012 Supercars on State Street Carlisle Judges pick Best in show!
chris410 is offline
post #107 of 278 (permalink) Old 06-18-2012, 02:07 PM
TrakRat's Avatar
Thanks for that Chris, but I stated many pages ago that my shifter can grind with my clutch pressed and held to the floor while shifting back and forth from 1-2. All while rolling with a cool car at 25 mph. Warm, not so much. It would appear the symptoms are varying a little from car to car.
'67 Coupe, '00 Exploder Limited, '11 GT500 Griggs Racing GR40SS - VMP TVS
TrakRat is offline
post #108 of 278 (permalink) Old 06-18-2012, 02:17 PM
chris410's Avatar
Is this with the OEM shifter or an altered one? I'm thinking if you've had several grinds, it may be worth having Ford do the warranty work then looking into the MGW shifter or perhaps the alterations detailed in the thread.
Either way, I hope you get yours sorted out!
Chris
chris410 is offline
post #109 of 278 (permalink) Old 06-18-2012, 04:16 PM
85glht's Avatar
Well, my car went in today for this issue. Of course, they could not produce the symptom. The tech said it shifted fine. Then the service writer told me to come in tomorrow morning to give the tech a ride so the grind can be duplicated. Well, I work so that will not happen. Great here we go. I HATE wasting my time. Going to pick it up in a few minutes and I'm gonna drive it like I stole it. If it grinds its going back WTF!!!
85glht is offline
post #110 of 278 (permalink) Old 06-18-2012, 07:53 PM
Shelby1's Avatar
Hi,
Just got mine back from the dealer. Problem is fixed and everything works like it should but the clutch pedal is now so refined. I hate the way it feels. There is hardly any resistance probably be great for traffic but loved they way the clutch used to feel. Wouldn't recommend the fix unless u absolutely need to have it done. The Tsb finally came out and all u have to say to the dealer is the car rolls forward when the cluth is down and show them the Tsb 10-3-8 and they are required to fix it. But like I said ur clutch pedal will not feel the same.
Sad.
Shelby1 is offline
1-2 shift grind mikenkaren Problems/Dealer Service 190 11-23-2011 07:13 AM
Is there going to be a recall for 1-2 shift grind? gkviper192 General Discussion 36 09-10-2011 03:23 PM
1-2 grind/lockout repaired craiger26 Problems/Dealer Service 1 07-01-2011 11:48 AM
1-2 grind issue fix coming in May, 2011 Late2Ford General Discussion 65 02-02-2011 06:23 AM
2010 2nd gear grind Slow Deal Performance Modifications 10 10-03-2009 06:13 PM
