What Is The Best 11" Wide Wheel Offset? - Ford Shelby GT500 Forum
post #1 of 37 (permalink) Old 10-24-2009, 01:22 AM Thread Starter
Newbie
Hi All, I Was Wondering If Anyone Is Running 18x11-19x11 Or 20x11 Without Issues. I Would Like To Know What Offset You Are Running And What Tire Size On The Rear? Also If You Had To Modify Anything? I Appreciate All Your Input.
Thanks
George
283E is offline
post #2 of 37 (permalink) Old 10-25-2009, 09:33 PM
TrickyDick's Avatar
Re: What Is The Best 11" Wide Wheel Offset?
I'm not sure you can go 11 wide without some die grinder use....
07 Performance White Red Stripe Ed.
Reborn in 2011 by Revan Racing - Griggs TT, Alum L&M built motor, heads, cams, w/KB 3.6, and so much more...
TrickyDick is offline
post #3 of 37 (permalink) Old 10-25-2009, 10:15 PM
2008GT500's Avatar
Send a message via AIM to 2008GT500
I have the Steeda Spyders 20x11, but I'm only running 295s INVOs for now, as that was the deal at the time. I'll keep you updated when I jump to a 315 or 335... There's no rubbing issues, but I'm not sure of the offset, I'm sure Steeda could tell you if you gave them a call.
2008 GT500 - 616rwhp 603rwtq
(#364/6513, #79/971 Vapor)
Performance: VMP tune/pulley, C&L intake, TR6 plugs, MGW shifter, Borla Touring, Dynatech headers, Ford Racing 65mm TB, Shelby HE, 170 t-stat, McLeod RXT, PST CF driveshaft, Cortex Watts link, Pilot SS, Steeda - LCAs, comp/street upper, coil-overs, bumpsteer, X5 ball joints
Appearance: Shelby plaque/sills, Steeda Spyder wheels, Formula 1 ceramic tint, shorty antenna, clear corners, Redline hood struts
2010 Corvette Grand Sport
2008GT500 is offline
post #4 of 37 (permalink) Old 10-26-2009, 09:22 PM Thread Starter
Newbie
Thanks For The Replies. I Thought There Would Be A Lot More With All The Supposed 11" Rims Out There. Thanks Guys For The Replies And 2008gt500 I Will Give Steeda A Call.
283E is offline
post #5 of 37 (permalink) Old 10-27-2009, 10:13 AM
I had the stock rims widend to 11" and run 335 30 ZR 18 Nittos on the back. Fit great with no grinding necessary.
jcthorne is offline
post #6 of 37 (permalink) Old 10-27-2009, 10:32 AM
El Jefe
rlhay2's Avatar
When I was researching I also inquired about offset numbers. None were ever divulged.
Even the wheel manufacturer I used prefered not to disclose the numbers only stating "We've done a GT500, we know what they should be."
Ronnie
eagerly awaiting '18 GT500 info
rlhay2 is offline
post #7 of 37 (permalink) Old 10-28-2009, 08:53 AM
Newbie
I just now saw your posting - for me I got 11" wide wheels from CCW (SP500's). I ordered them to be 52mm offset in the rear, and they are perfect. I run Toyo drag radials 315/35/18 on the rears. By the way, I still have at least 1/2" clearance to the inside from my tires to the shock, so pleanty of space when parking or going over uneven surfaces so they will not rub.
2008 GT500 Coupe
TVS Stage 2 Polished Supercharger upgrade with 2.6" Pulley & Evolution Tune
JLT Carbon Fiber Cold Air Intake & Radiator Cover
AFCO Dual Fan Heat Exchanger
EVO Aluminum 1-Piece Driveshaft, Borla Exhaust
J&M Billet LCA's & adjustible UCA
Fore Billet Fuel Rails, L&M Throttle Body
Stiegemeier Ported & Polished Plenum
Shelby Billet Short Shifter, 3.73 gears
CCW SP500 Forged Wheels 18x9.5 & 18x11
Toyo TQ Drag Radials 315/35/18
Girodisc 2-piece rotors front & rear
gtcpa is offline
post #8 of 37 (permalink) Old 10-28-2009, 01:14 PM
AVIATOR's Avatar
[QUOTE=gtcpa;56563]I just now saw your posting - for me I got 11" wide wheels from CCW (SP500's). I ordered them to be 52mm offset in the rear, and they are perfect. I run Toyo drag radials 315/35/18 on the rears. By the way, I still have at least 1/2" clearance to the inside from my tires to the shock, so pleanty of space when parking or going over uneven surfaces so they will not rub.
Stock Springs????
2010 Grabber Blue, STEEDA Springs & PANHARD Bar, FRPP 3:73 Gears, FRPP Axel Girdle, Jon Lund Tune, HIDGUY headlights and fogs 5000K, Whipple 2.9, Whipple CAI/MAF, FORE FUEL RAILS, 72lb Injectors, KR Mufflers - more mods to come just trying to finger it out.
#2 Member of the Call Jon Lund club!
Artwork courtesy of HAZMAN
AVIATOR is offline
post #9 of 37 (permalink) Old 10-28-2009, 03:33 PM
Newbie
[quote=AVIATOR;56586]
Stock Springs????
No, I have the FRPP racing springs which lower the car 1.25" all the way around.
2008 GT500 Coupe
gtcpa is offline
post #10 of 37 (permalink) Old 10-29-2009, 06:35 PM
AVIATOR's Avatar
Man I REALLY like those tires and wheels, BIG and PHAT! They look like they really hook up. I know that a lot of folks on here like the 19's and 20's. Yes they are more glamourous but these bad buys look like they mean BUSINESS. Do share, how do they ride, hook up etc....... Spare no details.
AVIATOR is offline
New Ford Racing "427 Cobra" Windsor Valve Covers??? BigBadCarGuy Performance Modifications 4 09-30-2009 03:43 PM
18" wheel question wyroadking General Discussion 20 11-09-2008 03:25 PM
Huge Site Wide JLT Pre Holiday Sale 2008 Tucker Performance Modifications 1 11-01-2008 02:39 PM
Nation wide inventory.... 1268 General Discussion 11 01-27-2008 09:32 AM
