L&M NSR cams installed. - Ford Shelby GT500 Forum
 14Likes
post #1 of 19 (permalink) Old 06-02-2017, 07:13 PM Thread Starter
VNMOUS1's Avatar
Purposely lost 100 pound feet of torque on the hit to pick up 80 rwhp above 5000rpm. Next week I am gonna put Christine on FTW fuel and let her eat.
Now, if it weren't 90f and 3,000 DA every day
Sent from my SM-G935V using Tapatalk
VNMOUS1 is online now
post #2 of 19 (permalink) Old 06-03-2017, 05:14 PM
avgt500's Avatar
Re: L&M NSR cams installed.
Have you driven it on the street yet? if so can you feel the loss of torque and does the hp gain feel worth it?
I'm debating on getting these for the next mod, problem is if I go that far I might as well do the oil pump, then while I have the balancer off it would be easy to throw on a 10%, then I will surely max out my 56s so I'm probably gonna need id1000's and a boost a pump, not sure if I can live off of top ramen for a year...
2008 GT500, VMP gen 2, VMP 67 tb, JLT ca kit, 56 inj, cats gone, 3.73's MGW gen2, nitrous express plate kit currently at 50.
avgt500 is offline
post #3 of 19 (permalink) Old 06-04-2017, 08:32 AM Thread Starter
VNMOUS1's Avatar
Because of the lope there is a slight difference in the way you leave a stopsign but there's no loss of driveability, per se.
You wouldn't feel a loss of torque in everyday driving nor on the track. Your short times at the track will generally improve with less torque as it won't be so hard to launch.
Fueling is dependent upon what you want to do with the car. Are you adding cams primarily for power? Then you'll need fueling. If you want a little more power and primarily looking for old school sound, you may be ok with the 56s and a booster. You would need to log and review.
avgt500 likes this.
post #4 of 19 (permalink) Old 06-06-2017, 06:32 AM
Junior Member
pierce88's Avatar
BJ,
What would you guys typically charge (Or just the number of hours) for the install of these, Motor in Car obviously?
You can PM if you'd prefer not post it around. Mostly just curious on the hours.
pierce88 is online now
post #5 of 19 (permalink) Old 06-06-2017, 07:34 AM
Carmine_GT500's Avatar
Cars with only 3 digit horsepower numbers are weak.
WOW!
VNMOUS1 likes this.
2007 Shelby GT-500
Performance White with Vista Blue LeMans and Side Stripes
VMP Gen II, 94 Oct VMP Tune, VMP 67MM TB, 2.5" pulley, '08 damper, 56lb injectors, VMP Dual BAP, Brisk plugs, JLT 127MM CAI, VMP Triple Pass HE with fans, VMP 3X Reservoir
FRPP/Tokico Struts, UPR LCA, Eibach Pro Kit Springs, Fays2 Watts Link, FRPP 3.73, Borla S-type axle back, JTL Oil Separators
Polk Audio db571 speakers
Carmine_GT500 is online now
post #6 of 19 (permalink) Old 06-09-2017, 08:19 AM Thread Starter
VNMOUS1's Avatar
Originally Posted by pierce88 View Post
BJ,
Sorry so long for an answer. I don't get notifications.
15 hours @ 100.
Engine must come out or add 6 hours.
post #7 of 19 (permalink) Old 06-09-2017, 09:11 AM
15 hours @ 100.
Out of curiosity, how long does it take to pull the motor? Does the 6 hours wash out compared to R&I of the motor?
Bartman is online now
post #8 of 19 (permalink) Old 06-09-2017, 09:22 AM Thread Starter
VNMOUS1's Avatar
About 2 hours. The issues are:
With motor in-
the drivers side valve cover is a real treat to R&R. I've done it a couple of times and its a PITA of monumental proportions
you're going to have to pull the front cover anyway so it's much easier to get to everything with the engine out
the rearward exhaust followers are a monumental pain in the ass to deal with due to the crap in the way (brake booster, lines, etc) and the fact that it's WAY down there.
With the motor out-
No valve covers to screw with.
Front cover MUCH easier to get to and remove
Much easier to check for unobstructed turning as you install each cap.
Much easier to get pulleys and belts back on
Much easier to assure you don't have crap bound or pinched as you put the valve covers and stuff back on (as me how i know said the man that was "missing" a fuel injector connector on the drivers side)
So, it's better all the way around to pull the motor.
post #9 of 19 (permalink) Old 06-09-2017, 09:29 AM
With motor in-
With the motor out-
Having never pulled a motor, I always thought it would be a monumental task but you make it sound easy here.
post #10 of 19 (permalink) Old 06-09-2017, 09:33 AM Thread Starter
VNMOUS1's Avatar
I didn't say that. I said it much better to do so.
Figure 2 hours out....3 to 4 back in....provided that nothing goes sideways. Much less chance of that happening with the motor out than doing it in the car.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
SVT4ME38, VNMOUS1
Any Vids of NSR Cams with full exhaust? Haney1993 Performance Modifications 12 10-02-2015 05:42 PM
L&M cams installed Cabikejumper Performance Modifications 35 09-06-2015 12:58 AM
FS: L&M Cams Nick13 Parts For Sale/Wanted 0 04-28-2015 06:59 AM
comp cams installed!! 007snake Performance Modifications 42 09-19-2014 05:53 PM
L&m cams SaltLakeCobra Performance Modifications 8 02-05-2013 07:42 PM
