What's the verdict on using an oil seperator? Do it or not? - Ford Shelby GT500 Forum
post #1 of 11 (permalink) Old 05-20-2011, 11:24 AM Thread Starter
I'm taking delivery of my '12 GT500 today. Already have the JLT oil separator at home.
I'm skeptical about the oil separator.... as in should i use or not? How in the world will a little bit of synthetic oil going down the blower "gum" anything up? Why didn't they do this from the factory? I'm tempted to return it.
zimm17 is offline
post #2 of 11 (permalink) Old 05-20-2011, 01:42 PM
shlbysvt's Avatar
Re: What's the verdict on using an oil seperator? Do it or not?
Alot of positive and negative on this one. Personally I believe it is part of the design. A little bit of lube never heart anyone and there is a drain in the plenum and no I am not running a seperator. Take the wife, girl friend, or whoever out for dinner. Better money spent in my opinion. Then again Justin may disagree. His does seem to be the best design for efficiency and plug and play.
[/I]Ordered - 3/24/06, Blend date - 8/21/06, Build date - 8/30/06, Gate release - 9/1/06, Shipped - 9/13/06, Delivery - 9/19/06, Coupe, Tungsten, Satin silver stripes, Charcoal interior w/upgrade, Shaker 1000, #96 of 384 Tungstens ever to be built.
Best run to date: 11.08 @ 126
shlbysvt is offline
post #3 of 11 (permalink) Old 05-20-2011, 02:38 PM
1 Alibi 2's Avatar
Had one on my 2011 till I did my blower upgrade on 04/29/2011.
The owner of the shop that did my work, JDM Engineering, Freehold N.J., Jim Sr. told me the blower needs lube because of the tight lobe clearances. Based on this conversation, I removed the seperator.
As with most topics, there are those that would disagree. I can only tell you what I'm doing with my motor.................years down the road, we'll all have the answer !!
" Chance favors the prepared mind "
2011 - lightly modded to 776rwhp....documented " 1 of 2 "
2014 - detuned to 780 rwhp
1 Alibi 2 is offline
post #4 of 11 (permalink) Old 05-20-2011, 03:44 PM
shlbysvt's Avatar
+1 I have read and been told the same.
shlbysvt is offline
post #5 of 11 (permalink) Old 05-20-2011, 04:27 PM
Alloy Snake's Avatar
My concern on this is the oil coating the intercooler which seems like it would decrease its ability to remove heat from the charge air.I have cleaned the intercooler several times and got it back to the nice aluminum color it shoud be-Not as easy now with the KB installed.
2008 GT-500,SS-KB Stage 3,IW 10% Lower,Suspension,Brake,And cooling mods.
Alloy Snake is offline
post #6 of 11 (permalink) Old 05-20-2011, 09:24 PM
mullens's Avatar
Sorry but I disagree. The blower has its own internal oil supply that lubes the gears and wear parts. The lobes DO NOT need lubrication, as they never touch. All you want is air going past the lobes. Oil lowers octane and is not good for the intercooler. It serves absolutely no purpose getting sucked in the intake.
2013 GT500 DIB /White
FRPP Resonator delete
AirRaid dry filter
MPSS
mullens is offline
post #7 of 11 (permalink) Old 05-21-2011, 12:08 PM
gassman's Avatar
2013???
gassman is offline
post #8 of 11 (permalink) Old 05-22-2011, 08:08 AM
One on the passenger side...none on the drivers side...5k miles of experience
Just my opinion
2010 Torch Red , 4.5L Whipple , Kooks LT, BMR suspension , Whipple TB , JLT CAI , IW +10% , 23# psi , 1000+ RWHP , 925 RWTQ , E 85 tune , MT DR
2010 Red & White is offline
post #9 of 11 (permalink) Old 05-22-2011, 12:45 PM
mullens's Avatar
Yes 80%-90% of the blow by is on the passenger side. Drivers side separator is not necessary IMO.
mullens is offline
post #10 of 11 (permalink) Old 05-22-2011, 04:15 PM Thread Starter
OK, I'll use the passenger one that I have. I skipped the driver's side.
zimm17 is offline
JLT Oil Seperator Update Fordx4 Performance Modifications 77 11-23-2011 10:43 PM
oil seperator msmap General Discussion 81 04-30-2011 11:23 PM
Latest Engine Pics with Oil seperator Svtbird91 Performance Modifications 106 02-04-2011 06:23 PM
