I have a new set of rims which I am going to have new rubber mounted on in the next couple of days. I purchased new rubber stem TPMS sensors and need to install them. Can anyone share there experience on what the best way to install these?
I know the stem can simply be pulled thru the hole but does the stem need to be lubricated? If so what can I use?
Also, does the TPMS have to be removed from the stem body before installing?
What would be the easiest way to pull the stem thru the hole without having to buy a special tool?
I'm just trying to do this part myself to limit the possibility of the tire shop marking up my rims. If its better just to have the tire shop do it and take my chances, I would appreciate that feed back also.
So it sounds like you purchased the rubber stem type valve stems with the tab on the bottom for the sensor attachment instead of the screw together TPMS stem assy.?
If it is the rubber stem they pulling like a regular rubber valve stem, the install tool will be the best thing to use, you do not want to damage the rim lip. Me personally, I would use water soap solution as is many times used to install the tire on the rim.
There are other valve stem tools that "could" work to pull the stem in place, like the T-shaped multi-tool, but getting a good grip on that tool will probably be the issue once it is screwed over the stem threads
Actually the one sensor that I showed in the two pictures was from a set I removed from a 2011 Super Snake set of dark Alcoa's. Shelby installed them in the wheels and I assumed they were oem 2011 Mustang?
I'm pretty sure the second picture was the sensor out of that black Alcoa, but they (all four) had an oem looking silver TPMS stem in those dark wheels. That is why I started a search for dark hardware for this type of TPMS set-up, to blend the stem in against the dark wheel.
Thanks ... I lucked out and the tire place had a set similar in stock and I got them to install them for me. Got my new rims and tires mounted and I installed them today.
