Broken Spark Plugs!!! - Ford Shelby GT500 Forum
post #1 of 7 (permalink) Old 08-18-2010, 09:50 AM Thread Starter
rjm-1's Avatar
Have you guys heard about this? "Some Ford with 5.4 engines may experience difficulty with spark plug removal which may cause damage to the spark plug and leave part of the spark plug in the cylinder head."
This just happened to my buddy on his GT with a 4.6 engine when he tried to change plugs. The ground electrode shield portion is stuck in the cylinder head. The only way to remove it is to use a thread tap being careful to not let any chips fall into the combustion chamber. You need to use a a modified vacuum cap (382444-S) as a stopper-type plug.
I have a 2008 Gt500 with almost 10K miles. Makes me want to pull my plugs and coat the shielded portion with anti-seize compound. But I think I'll just leave it alone. Don't fix it if it ain't broken!
For those interested, here is a link to the removal procedure. (entry #12) http://allfordmustangs.com/forums/20...park-plug.html
rjm-1 is offline
post #2 of 7 (permalink) Old 08-18-2010, 01:43 PM
VNMOUS1's Avatar
Re: Broken Spark Plugs!!!
1. Use anti-sieze
2. Don't tighten the crap out of them. Snug, then a little more.
3. Change them a ton more often than the book calls for. I change mine at every oil change- 3,000 miles max- because they're seeing tough duty, but they're not going to sieze that way either! They're 2 bucks a piece and about 30 min labor in your garage. Let's see....$16.00 for plugs, $6.00 for a six pack, piece of mind: Priceless.
VNMOUS1 is offline
post #3 of 7 (permalink) Old 08-18-2010, 02:06 PM
Alloy Snake's Avatar
The plugs in the 3 valve motors are some goofy design-And yes there are many tools to remove the broken pieces-Happened to me on my 05 5.4 truck.The 4 valve heads use a normal spark plug that dont have the issues of the 3 valve heads.
2008 GT-500,SS-KB Stage 3,IW 10% Lower,Suspension,Brake,And cooling mods.
Alloy Snake is offline
post #4 of 7 (permalink) Old 08-19-2010, 12:32 AM
Joe G's Avatar
Yep... it's the old 5.4 2-valve engines, not our 5.4 4-valve engines.
But what BJ said is true - don't let them sit in there forever. Change them at least every other year - I'm on the once a year plan b/c as BJ said they're cheap. Use anti-seize and you'll be good to go.
Proud owner of a 2007 GT500 Convertible - 853/859 Black verts, 2674/2695 all verts
- Black, white stripe
- Red accent leather int, Nav, Sirius, Premier Trim pkg, cover
- $500 below MSRP
- 0% interest thanks to Ford!
- Shelby signed dash plaque
- GT500 Snake dead pedal
- Shine by ICE - thanks to my dawg Snoop!
Capo di Tutti Capi of the Black Vert Mafia
Joe G is offline
post #5 of 7 (permalink) Old 08-19-2010, 04:03 PM
NUROTOXN's Avatar
Great advice gentlemen. I had a Porsche 928 where the mechanic should have, but didn't use anti-seize upon replacing the water pump. Because of the combination of aluminum block and the antifreeze it locked in the waterpump bolts like cement. The heads of each bolt snapped off upon trying to remove them. The engine had to be pulled and then carefully drill and tap the frozen bolts. If I were a new 2011 owner with an aluminum block, I would get to know the service reps and be very selective about where I take my Shelby for service.
Stock 2007 Shelby GT500 Vert; Oct 2006 Production
Purchased at Ford SVT Dealer, Shelbyville, IN
NUROTOXN is offline
post #6 of 7 (permalink) Old 08-19-2010, 07:54 PM Thread Starter
rjm-1's Avatar
Originally Posted by VNMOUS1 View Post
1. Use anti-sieze
Do you coat the spark plug threads with anti-seize compound? And how does this affect torque? I've heard pros and cons about use on spark plug threads.
rjm-1 is offline
post #7 of 7 (permalink) Old 08-19-2010, 09:15 PM
6-Speed's Avatar
When I changed the plugs on my Honda van and car, I applied anti-seize to the spark plug threads and tightened the plugs to 85% of specified torque.
6-Speed is offline
Broken gauge or alot of boost?? Gilgamesh Performance Modifications 5 04-08-2010 04:52 AM
Spark Plugs Blackmax General Discussion 5 12-17-2009 01:28 AM
Stock Spark Plugs TrickyDick General Discussion 24 06-24-2009 07:06 PM
Spark Plugs 2008GT500 Performance Modifications 3 03-03-2009 03:33 PM
Broken 5th gear joegaz Problems/Dealer Service 5 09-26-2008 09:02 AM
