Gt500 shelby 2014 max tire sizes - Ford Shelby GT500 Forum
 1Likes
post #1 of 20 (permalink) Old 09-03-2013, 08:52 AM Thread Starter
Newbie
Are the max tire sizes for the 2014 gt500 275 front and 295 rear?Going to order the MPSS want to put the widest on possible
GT500S is offline
post #2 of 20 (permalink) Old 09-03-2013, 10:23 AM
stkjock's Avatar
Re: Gt500 shelby 2014 max tire sizes
no
if you use the search feature you'll find many threads on tire size.
CORN POWERED-4.0L WHIPPLE BLOWN-L&M Engines Built-Lund Racing Tuned
Gone but not forgotten Vortech Blown Vert 11.49 @ 121.45
stkjock is offline
post #3 of 20 (permalink) Old 09-03-2013, 11:38 AM
T3RMIN8TOR's Avatar
Yes, and that's what I put on mine. World of a difference!!
Sent from AutoGuide.com Free App
2013 Fully Loaded
Mods:Ported TVS 2.3, XBA Elbow, KB 168mm TB, JLT 155mm CAI, ATI 10% Lower, 2.4 Upper, Gates Blue Belt, Thump Tensioner, Metco Idler, ID 1300's, KB BAP, 170* Thermostat, Steeda Lowering Springs, Steeda Chasis X Brace, Cortex Watts Link, Cortex Torque Arm, Cortex Adj. LCA's, ARH 1 7/8'' LT With O/R X Pipe, and SW Cat Back, SS Clutch and Brake Lines, McLeod RXT, MGW 2, VMP TP H/E, BMR Front Sway Bar + End Links, Canton Fuel Filter, E85 Lund Tune = 830rwhp + 845tq
T3RMIN8TOR is offline
post #4 of 20 (permalink) Old 09-03-2013, 02:00 PM
stkjock's Avatar
you can fit bigger rear tires than a 295 on a 13+ Shebly
stkjock is offline
post #5 of 20 (permalink) Old 09-03-2013, 02:27 PM
TrakRat's Avatar
Metric ton of variables and threads about this. Stock wheels? Aftermarket? Widened? Lowered?
'67 Coupe, '00 Exploder Limited, '11 GT500 Griggs Racing GR40SS - VMP TVS
TrakRat is offline
post #6 of 20 (permalink) Old 09-03-2013, 03:13 PM
440sprint's Avatar
295's are largest for stock, rear, PP rims without bulging. I put 285's on the front to successfully reduce the front end from scraping the lower splitter. My car handles just fine, way better that the GY's!
440sprint is offline
post #7 of 20 (permalink) Old 09-03-2013, 05:34 PM Thread Starter
Newbie
Tires are going on Alcoa 50TH wheels, 20x9.5 front and 20x10 rear.Want to order the Michelin MPSS was hoping for 285 front and somebody mentioned 315 rear??
GT500S is offline
post #8 of 20 (permalink) Old 09-03-2013, 10:25 PM
Madlock's Avatar
Aha! There's the rest of the story. This isn't just about tire size. It's about what tire, by what maker on what wheel with what offset with which suspension. Whether the tire rubs circumferentially, protrudes or you need to start hacking away bits of your suspension is a product of all the above.
You're not likely to find a 315 for anything narrower than 10.5" wheels. But not all makers' 315s are the same diameter - nor do they have the same tread or sidewall width. A 315/35-20 Conti DWS barely rubs under full compression on a 10" wheel. On an 11" wheel, it likely wouldn't. It also wouldn't sit so proud of the fender well. But if you've changed your suspension setup, you've reset the entire equation.
If you have a particular set of wheels and tires in mind, the question usually becomes self-answering by the tire sizes available. About the only option becomes what size fronts to choose - which will greatly impact ride quality and the car's steering balance.
Some GTs, GT500s, GT350Rs and maybe even a BOSS 302.
Madlock is offline
post #9 of 20 (permalink) Old 09-04-2013, 05:46 AM
Funky Spunky
03reptile's Avatar
Send a message via AIM to 03reptile
Well Said, Madlock.
03reptile is offline
post #10 of 20 (permalink) Old 09-04-2013, 07:52 AM
stkjock's Avatar
/\ This & \/
IMHO a 315/35ZR20 will be ok on a 10" rim, is it optimal, nope, will it work, IMO yes. It's spec'd for a 10.5" min rim, to me, based on my experience and readings, a .5" difference is doable. It will be a tall tire at 28.7" and could cause rubbing issues if you're lowered.
a 305/30/20 is probably a better choice.
stkjock is offline
Rear tire sizes fayo16 Wheel & Tire Section 18 01-24-2013 08:46 PM
Tire Sizes MI GT500 General Discussion 5 10-02-2012 06:32 AM
Tire sizes on a 2012 GT500 icar General Discussion 2 02-22-2012 10:47 PM
Tire sizes Spazpilot General Discussion 3 02-05-2011 06:10 PM
What tire sizes if you switch to 20's?? JINXER General Discussion 11 05-26-2009 05:24 PM
