EPAS Turning noise ?? - Ford Shelby GT500 Forum
post #1 of 13 (permalink) Old 09-19-2011, 03:39 AM Thread Starter
Minicobra's Avatar
Started noticing this noise when turning tightly in parking lots or on a sharp right hander. It almost sounds like an old power steering pump sound.
It seams like it started shortly after installing Eibach Pro-Kit springs, but maybe I just started paying more attention. Also, seams like the sound is louder after the car warms up a bit. It's possible something is rubbing, but it doesn't feel like it. Maybe a problem with the EPAS unit?
I'm running stock tires and wheels on the 2012 SVTPP pack.
Anyone having a similar problem?
2012 GT500 SVTPP, Bassani Exhaust - FRPP Res Delete, Airaid Filter, Eibach ProKit, Koni Yellow-Sports, BMR PHB. AG M310 20's rims. Other rides: 2011 WRX, 370Z-SOLD, Mini Cooper JCW. Past Mustangs: 91 LX 5.0, 1969 Mach One, 1970 Boss 302.
Minicobra is offline
post #2 of 13 (permalink) Old 09-19-2011, 06:18 AM
Funky Spunky
03reptile's Avatar
Send a message via AIM to 03reptile
Re: EPAS Turning noise ??
There are two issues that are possible if your suspension were stock, which it is not; however, I'll throw them at you for grins. (1) there was a TSB for the 2011's reference an electric steering re-programing due to some slight steering nibbling and on center feel. (2) This noise also could be your traction lock rear end "moaning" a little on turning. Mine will do it going out of the driveway. If these issues aren't the culprits and with the Eibach changes, I'm at a loss.
03reptile is offline
post #3 of 13 (permalink) Old 09-22-2011, 09:42 AM Thread Starter
Minicobra's Avatar
I never thought of the rear end, it really sounds like it's coming from up front. Being a 2012, shouldn't it already have the update on the TSB?
It's weird because it doesn't do it first thing in the morning, pulling out of the drive way or making a u-turn, but once the car warms up, you can hear.
It really sounds more like an old power steering pump that needs fluid.
Does the EPAS unit require fluid?
I think I'll pop the car up on jack stands this weekend and take the front wheels off, turn the wheel from side to side and see if I can find anything.
Probably wont do it though, since it won't be under load.
post #4 of 13 (permalink) Old 09-22-2011, 10:14 AM
Newbie
MDPLS's Avatar
I don't want to sound like an idiot, but... what is steering wheel nibble?
MDPLS is offline
post #5 of 13 (permalink) Old 09-22-2011, 10:35 AM
Colleton's Avatar
From the OP's description, it's almost certainly noise from the differential, not the EPAS. The differential clutch pack moan is normal, but can be minimized/eliminated by adding some friction modifier.
For the OP, the EPAS is electrical in nature, there are no fluids. Just a computer controlled electric motor.
2017 GT350: Ruby Red Metallic w/Black stripes + Convenience Pack
Ordered: 14 July 2016
Produced: 30 Sept 2016
Delivered: 17 Oct 2016
Colleton is offline
post #6 of 13 (permalink) Old 09-22-2011, 11:18 AM
Snake Doc's Avatar
I had that problem with my '09 and again with my current '11, one bottle of the Motorcraft additive "Friction Modifier" added to the differential solved the problem.
Before you spend a lot of time and money hunting the source of the noise, add the Friction Modifier, about $7 - $8 from your local dealership and if they want a large labor charge, add it yourself (it should be a warranty item anyway).
Here are the relevant portions of TSB-05-10:
8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE TSB 08-5-10
DURING LOW SPEED TURNING MANEUVERS
ISSUE
Some 2005-2007 Mustang GT vehicles equipped
with the 8.8 inch limited slip axle may exhibit a
moan/groan noise when making tight low speed
turns. This may be more noticeable when the axle
is at full operating temperature. The noise may also be confused as originating from the brakes or steering system.
SERVICE PROCEDURE
1.
2.
3. Vehicles built after 10/22/2006 were built with the new limited slip clutch pack. For these vehicles, add 1 bottle of Motorcraft Additive Friction Modifier to the axle. Perform several full lock turns at low speeds in both directions to force the lubricant into the limited slip clutch pack.
Good Luck!
Cruise On,
Ron/Snake Doc
"It's never too late to have a happy childhood!"
2011 Red/White GT500 SVTPP; Hood lifts, CAI resonator eliminator,
'07-'09 Strut Tower Brace, & JLT Splash Guards
Snake Doc is offline
post #7 of 13 (permalink) Old 09-22-2011, 11:47 AM
MJD
Newbie
I have a 2010 and just installed the same springs and adjustable panhard bar. I picked up the same noise as you are describing. I think something is rubbing and it is more prominate when I have a passenger. So that would indicate a left front "rub" of some sort.
MJD
2010 GT 500
Grabber Blue / white stripe
MJD is offline
post #8 of 13 (permalink) Old 09-22-2011, 12:02 PM
prboss's Avatar
mine has same noise. roundabouts.
Cold Snake, 2011, Anchorage AK.
prboss is offline
post #9 of 13 (permalink) Old 09-22-2011, 02:49 PM
JFH
JFH's Avatar
I had the same noise you are describing in my 09 while making tight turns. I took it to the dealer, the tech went for a ride with me and heard the noise. No questions asked they replaced the clutch packs in the rear end under warranty. No more noise. Take it back to the dealer and they should take care of you.
JFH is offline
post #10 of 13 (permalink) Old 09-23-2011, 01:42 AM Thread Starter
Minicobra's Avatar
Thanks Colleton, Snakedoc and everyone else :-)
I thought for sure it was coming from the front, but I drove it this morning around the cul de sac (when cold) and got no noise.
After driving around a bit (15min) did the same thing, noise was there.
Tends to get louder the warmer it gets.
If I install the friction modifier, do I need to drain any fluid out first?
Creaking sound while turning? bsmoke Problems/Dealer Service 13 03-03-2012 06:05 AM
2011 SVTPP -- clunk/grind when turning at full lock Convert Problems/Dealer Service 13 04-22-2011 08:40 AM
'09 GT500 Lights Turning On Randomly ptssmith General Discussion 6 01-19-2011 04:39 PM
VMP TVS noise PARTS DUDE Performance Modifications 11 01-17-2011 09:44 AM
Gear Rollover Noise or Throwout Bearing Noise? frisco General Discussion 8 12-10-2008 12:47 PM
