Changing Supercharger oil. Intercooler liquid? - Ford Shelby GT500 Forum
post #1 of 5 (permalink) Old 05-15-2011, 07:46 PM Thread Starter
bsmoke's Avatar
Question Changing Supercharger oil. Intercooler liquid?
Ok my car is an 08 GT500 but only has 4500mi. on it.
I have found records of oil changes but non for supercharger oil change.
How often do we need to change the oil in the supercharger?
Also.. does the intercooler have a liquid we need to change out and how often should we do so?
Thanks!
bsmoke is offline
post #2 of 5 (permalink) Old 05-16-2011, 07:26 PM
Re: Changing Supercharger oil. Intercooler liquid?
It should say in your manual when to change it, if at all. I haven't seen a stock blower in a several months, but if I recall, the gear case is sealed and the oil can't be changed. I'm probably wrong, though, as that wouldn't make much sense.
'11 GT500 Kona Blue/Silver
FRPP 750HP Whipple 2.9L
FRPP SCJ mono-blade throttle body
Kincaid Perf. Killer Chiller
Revan Racing I/C reservoir
MGW shifter
Eibach Prokit springs/dampers/camber bolts
BMR boxed subframe connectors, UCA & mount, adj. Panhard & brace, A-arms, K-member, radiator support, LCA relo brackets
Bob's LCAs
CHE A-arm support w/ torque limiters
DSS carbon fiber driveshaft
Boss 302 rear seat delete/x-brace kit
GT Premi is offline
post #3 of 5 (permalink) Old 05-17-2011, 09:25 AM
Eaton says its lubed for life. Steigmier says 50k. Mine has had Rotella T6 Syn 5W40 in it for 25k+
jcthorne is offline
post #4 of 5 (permalink) Old 05-17-2011, 09:44 AM
Seahorse's Avatar
There's a fill port plug on the front accessed with an allen key.
2009 Shelby GT500 Convertible Ebony/Red/White
11.42 @ 124.37
Seahorse is offline
post #5 of 5 (permalink) Old 05-17-2011, 11:41 AM
MRL Performance's Avatar
the factory oem supercharger oil is "supposed" to be filled for life, good forever. the only way to change it(short of removing the snout) is either through the fill port by sucking it out, or removing the blower and dumping it out the fill port. in reality, you should never have to worry about it. maybe if you had 50,000+ hard miles, i would think about it. i have taken eatons apart for porting that had 30-50,000 miles on them, and the oil still looked pretty good.
as for the intercooler system, every 3 years is a good rule of thumb. it only holds about 3 liters anyway (stock), so not a big deal. pull the hose on the heat exchanger at the bottom on the passanger side and let it drain. fill it up, run the intercooler pump for a few minutes, then top it off.
MRL Performance is offline
stock supercharger air intake intercooler tank and lower pulley 2008gt50015 Parts For Sale/Wanted 1 11-05-2010 11:01 AM
Changing tunes on an SCT X3. Wally Gator General Discussion 4 09-01-2010 08:59 AM
changing gears, is this true? clear front sight Performance Modifications 4 07-21-2010 05:22 PM
Oil Changing Mileage ShelbyBanker General Discussion 30 07-02-2010 07:28 PM
